chefdennis
Guido, see if you can work it out with Wombat, use hs s-10 thats in the lot. Drive up there, rent a tow bar from U-haul and tow it back behind the cube....just a thought...
Maybe the flugelbinder?I sure hope it is found before actually letting loose, costing some seroious money.
On a different note, If anyone is going from the office to taylor,
I am needing a ride to ****atoo, Mn, West of St.Paul/Minneapolis to pick up the new ride..This would be the cheapest, easiest option...
sounds like in the engine area...That's one reason I wanted him to say where he is hearing the noise. Engine area or under the van.
well it is a slow build up till full peak noise...then 3-4 and it slowly subsides....I m betting on the wastegate sticking open then slowly closing...Steve is that vacuum operated by a big vacuum operated actuator or set to open at a pre-determined exhaust flow pressure??
I may not be hearing a leak..I was describing a sound to type..Well...the wastegate on a turbo motor is basically a "by-pass" of the turbocharger when the exhaust pressure reaches a set pressure..it then bypasses the turbo but it is dumped into the exhaust, not the atmosphere..so for you to hear the exhaust noise, there would have to be a leak...sooo..maybe its not that, but I'd have it checked...if it that is it and it decides to stay open, you will have no turbo pressure at all...
since it didn't cost me for a diagnostic..seriously considering Berry Dodge where I've had work done...in Corsicana Tx about 240 miles up the road....2nd opinion...
I don't think "waiting" for it to break is a plausible solution...I don't like it....I'd second that motion...hate to have you break down cuz one tech hadn't come across the problem before..
we might not like the answer...but IF it is serious I'd rather have Dave in Corsicana work on it...and they will deal in prices...!
north 35 looks good...am outta here gps says 215 miles...will call you when mobile....they are closed now...Did you call them yet?
