Keep the personal comments out of it...stick to the facts without personal commentary and all is ok...a "heated" debate can be exhilerating....LOL...
"For those who cannot handle the physics of carrying extra pallets off the deck because of thoughts like high center of gravity that comes with decking freight; Can those who do carry extra pallets ask the obvious questions. Have you never had freight loaded that utilized the entire capacity of your box, front to rear, and deck to ceiling? Was it tippy, high center of gravity?"
Indeed I have hauled to capacity regarding weight (13,000) and floor space/vertically. Was it decked skids....no. Was it tippy, not so much as to make it unsafe.
"Safely driving the load because it had a high center of gravity was never an issue; we train to not spin out on curves with top heavy loads."
Top heavy loads can be handled safely providing proper care is taken while transporting. The more one has done it the easier it becomes. There is always the unexpected that can and will eventually show up, ie: heavy cross winds, some fool about to miss their exit and cutting you off, wildlife appearing in front of you to name a few.
IMO there is a higher probability that decked loads will shift causing damage to the freight and or equipment. Therefor I will not deck. And am supported by my carrier in this by their discouragement/not allowing us to do so due to increased liability.
"And now folks, to the cheap shot of the day as quoted from Slacktide; So is there a "super trucker" badge that comes with fitting more skids, or is it just for bragging rights and for the "look at me look at me" that comes with it? Lugnut says, Nope, but we can give you a pacifier to go with those milk run loads you get."
Milk run loads? Who said anything about milk? Are you thirsty? or wanting cerial? No I will pass on the offer of the pacifier. In reading your posts in just this thread alone you seem to need it more. Now had you offered a ladle for gravey loads I may have taken you up on that.
Don't forget this poster and slacktide got into a tirade in the thread where the drivers were asking for help with their deadbeat owner forcing the moderator to close the thread. Some like to think they have the bully pulpit.
As it is quite impossible to gleen any kind of opinion whatsoever from a YES/NO answer to the question posed, the above stated reason appears disingenuous at best. It would appear that the thread was started to compile a list of YES/NO drivers who do and do not use some kind of decking system, so that at some later date and time one could then solicit opinions of their system either publicly or privately. The reason people answered the question, and the accompanying comments, with questions or comments of their own is because that's how threaded message boards where people can reply to forum postings actually work. So you shouldn't be shocked, surprised or mad because things worked out that way....one reason I started this thread was to get the opinion from those who are using some sort of method for handling more than their deck capacity of freight as to what they feel is a safe weight per pallet for the method they use.
No, it's not much to ask at all, if you were asking it in a poll which requires a YES/NO answer with no comments required, except in this case you opened that door with comments of your own along with the question. Of course, raw anonymous answers in a poll won't give you that list to follow up on. You'd still need people to post replies under the poll in order to obtain much in the way of opinion.Ah, let me get this right, I ask a question and I get questions. The question was legitimate, clear and concise. A yes or no shouldn’t be much to ask, don’t you think?
Considering the physics involved in a high center of gravity is not conducive to, and would tend to even prevent spinning out on curves (gravity, friction, angular momentum, inertia), and is more conducive to tipping over on curves, I'm curious... how would one train to not spin out on curves with top heavy loads? It's a legitimate question.For those who cannot handle the physics of carrying extra pallets off the deck because of thoughts like “high center of gravity that comes with decking freight”....
...we train to not spin out on curves with top heavy loads.
Load up that Krautmobile and practice the Spinout On Curves Reaction Drill.I'm curious... how would one train to not spin out on curves with top heavy loads? It's a legitimate question.
The system uses clips that hook into the current horizontal etrac on your cargo box walls which in turn, the clips hold 5 foot sections of etrac vertically. With the clipped in etrac you can then move the load bars up and down vertically as needed.
Oh yeah, almost forgot Moot, it’s a 22’ box, but only offer 240” inches to clients.
Plus:
I do not believe my carrier would allow it.
I do not think the walls of my box were designed for this type of loading.
I could just see a fork lift driver putting a skid through my translucent roof. (They tear up my floor and e track enough as it is.)
I don't think any extra money would be worth the additional problems that could occur.
Greg, one reason I started this thread was to get the opinion from those who are using some sort of method for handling more than their deck capacity of freight as to what they feel is a safe weight per pallet for the method they use. We have set a max limit of 600 lbs. per off the deck pallet. What weight limits have you chosen?
For those who cannot handle the physics of carrying extra pallets off the deck because of thoughts like “high center of gravity that comes with decking freight”; Can those who do carry extra pallets ask the obvious questions. Have you never had freight loaded that utilized the entire capacity of your box, front to rear, and deck to ceiling? Was it tippy, high center of gravity?
A recent run we had that was hand loaded utilizing our total capacity in both weight and space was indeed tippy, high center of gravity. Safely driving the load because it had a high center of gravity was never an issue; we train to not spin out on curves with top heavy loads.
And now folks, to the cheap shot of the day as quoted from Slacktide; “So is there a "super trucker" badge that comes with fitting more skids, or is it just for bragging rights and for the "look at me look at me" that comes with it?” Lugnut says, “Nope, but we can give you a pacifier to go with those milk run loads you get”.
Where do people think all those van loads disappear from in laredo?![]()
This has been going on for years and been posted on about the same amount of times. Where do people think all those van loads disappear from in laredo?![]()
I remember posting on this years ago and some were bent on it not being "true expedite". Mainly because it wasn't "exclusive use". The load gets an exclusive pallet next to another exclusive shipment that pays a expedite rate.
I then declared it a "exclusive load".![]()
I didn't way you were. I was very careful about that in my wording, as I don't really know your intentions or motives. I said the stated reason (which you stated, true enough, and thus you) appears disingenuous, which leaves room for doubt.Choice A; How can you say I’m disingenuous? I’m trying to live up to every cheap shot I make, I’m crushed you feel I have failed in doing so.
Always.Are we having fun yet?
That would be awesome. Can't have too many pictures to look at when trying to come up with ideas.No pictures, no links. Though I’ll see what I can put together for you.
The reason I asked about the floor length is the odd number of pallets you mention in this post. With approximately 2 extra feet to play with, you should be able to park the pallet jack in a pallet and still be able to close the door(s).
