Chevy Van brakes problem
Discussion in 'Truck Talk' started by Mike99, Aug 4, 2009.
  1. Mike99
    Mike99 Veteran Expediter
    Jan 2, 2008
    382
    145
    Ratings:
    +33 / 0 / -0
    Chevy Cargo van 2500 from 2005.
    When I push the brakes the van starts shaking. Everybody told me it's the rotors. Today I changed both front rotors but when I push the brakes it's still shaking. If I do not press the brakes it doesn't shake. Can somebody advice me what could the problem be?Thanks
  2. piper1
    Adorable
    piper1 Veteran Expediter Owner/Operator
    Sep 22, 2007
    1,804
    330
    Ratings:
    +1,355 / 4 / -0
    You replaced both front rotors and it still shakes......do you feel the shake in the steering wheel (as in it wants to turn the wheel).
    • greg334
      greg334 Veteran Expediter
      May 8, 2005
      20,280
      538
      Ratings:
      +42 / 0 / -0
      First thing I always ask - did you change the pads too?
      I know a lot of people skip this step but it is very important for the pads to be changed at the same time.
      Also knowing that some vehicles had rear brakes at one time :p, did you pull the drums (or rotors) and have them checked?
    • Mike99
      Jan 2, 2008
      382
      145
      Ratings:
      +33 / 0 / -0
      nO,i did not change them.they were ok.should I change them?
    • Mike99
      Jan 2, 2008
      382
      145
      Ratings:
      +33 / 0 / -0
      The pads.
    • chefdennis
      chefdennis Veteran Expediter
      Mar 7, 2008
      11,985
      288
      Ratings:
      +25 / 1 / -0
      Carrier:
      Load 1
      you didn't say what gvw the van is, if i am right the 8600 lb gvw has the same 8 lug press on rotors as the 9600 lb 1 ton van ,if the rotors are the type i think they are, yes change the pds and alos..make sure that the rotor is flush with the hub face...they come off with 2 bolts that you screw into the face of the rotor and hit against the face of the hub. Rust will get between them and can cause the rotor to not sit flush or flat against the hub....the old rotors were warpped, and that will also cause high and low spots on the pads tht will cause the shake. I can tell you my 1 ton did the same thing when i replaced the hubs, until i took it back apart and made sure it all went together clean and square,,,,
    • Dakota
      Dakota Veteran Expediter
      Nov 7, 2008
      5,311
      188
      Ratings:
      +4 / 0 / -0
      Carrier:
      I never run, I walk
      Yes you should change the pads any irregular wear caused by the old rotors may cause vibration plus the pads may wear the new rotors faster.
      Also, check your front suspension, jack up the van check wheel bearings, check your tie rods, check everything up there for looseness.
      And if your van did come with rear brakes :p check those too!!!
    • guido4475
      guido4475 Veteran Expediter
      Mar 17, 2008
      6,253
      405
      Ratings:
      +1,373 / 3 / -0
      Carrier:
      an awesome company
      As suggested here before, always change the pads with a new set of rotors.Also, did you torque the lugnuts? or just use an impact. Sometimes that does make a difference.Another question that comes to my mind is, where did you buy the rotors from? From a quality auto parts store like Napa, or someplace that cant find a part if it is not in the computer? There is a big difference in rotors from places like this, you get what you pay for.
    • fastman_1
      Arthritic
      fastman_1 Veteran Expediter Owner/Operator
      Dec 28, 2003
      6,769
      905
      Ratings:
      +10,877 / 12 / -1
      I can't add anymore than whats been said, Get a Top of line set of Pads and that should take care of the Problem, Also Change the Slide Bolts, I just had 2 snap on my 03 Savanna 2500, and A month ago another Driver I know with a 03 Chevy 3500 had 2 snap on his van, Neither Time were we braking hard or under a load, Just Snapped then a awlful Rattle.
    • Moot
      Confused
      Moot Veteran Expediter Owner/Operator
      Dec 26, 2005
      10,758
      1,005
      Ratings:
      +7,283 / 5 / -1
      Carrier:
      Panther
      Vehicle:
      Transit 350 Long/Tall Ecoblast
      I've got 375,000 on the original front pads. I did have a shaking problem like you described. My mechanic found a loose or sheared pin or bolt that supports the caliper assembly. When the brakes were applied the caliper assembly would move, causing the shaking. I don't have the work order with me that describes what he replaced. The pads and rotors were in good shape.
    • Dakota
      Nov 7, 2008
      5,311
      188
      Ratings:
      +4 / 0 / -0
      Carrier:
      I never run, I walk
      With 375K you probably had some metal fatigue going there
      :eek:
      I'm not familar with the Chevy Express brakes but if the pin you are talking about is the one that acts like a hinge once you remove the bolt from the caliper. Make sure it is snug and not loose unless this is the pin that the caliper slides on then make sure it slides on that pin, use some brake caliper lube.
      Not sure the type of caliper this van uses, since I have never done brakes on a Chevy Express
    • chefdennis
      Mar 7, 2008
      11,985
      288
      Ratings:
      +25 / 1 / -0
      Carrier:
      Load 1
      again not knowing the gvw creates an issue, the 8 lug wheel on the 8600 lb gvw chassis has sealed wheel bearing like the 1 ton van, they can not be adjusted. they are sealed in the hub...
    • fastman_1
      Arthritic
      Dec 28, 2003
      6,769
      905
      Ratings:
      +10,877 / 12 / -1
      They are the same on the 2500 with 6 lugs.
    • guido4475
      Mar 17, 2008
      6,253
      405
      Ratings:
      +1,373 / 3 / -0
      Carrier:
      an awesome company
      The sealed bearing thing must be on a G.M.,because every Ford I have worked on, (van , pickup,) has the wheel-bearing cap that you take off in order to get to the cotter pin,and a couple of washers, cotter-pin retainer, and then pull the bearings out,then the rotor comes off.Of course, I havent worked on a G.M. product in years, so it's hard to say what has changed.
    • fastman_1
      Arthritic
      Dec 28, 2003
      6,769
      905
      Ratings:
      +10,877 / 12 / -1
      A month ago I would have agreed 100% Friends Van has 500,000 Miles with the Orinagal Slide Bolts, My van has 400,000 and has had Front brakes Twice and each time I've changed all the hardware.
    • fastman_1
      Arthritic
      Dec 28, 2003
      6,769
      905
      Ratings:
      +10,877 / 12 / -1
      Must be since my Grand am and Bonneville both have the sealed hubs.
    • Mike99
      Jan 2, 2008
      382
      145
      Ratings:
      +33 / 0 / -0
      Thank you guys. Chevy 2500 from 2005 GVW 8600. 8 lugs. Also my mechanic said: ""It doesn't have the same rotors as the 9600 lb van...they are different.
      The rotors are held on by the lug nuts.
      Yes, it's best to change the pads, but pads will not cause a vibration.
      I can check for rust on the hub face, that is possible, but I would think
      that it would cause a very bad vibration stopping from any speed with
      that condition.
      I also mentioned that it might be the new rotors. But those Duralast
      rotors are good ones. It's the Valucraft that are junk""
    • usaf6186
      usaf6186 Veteran Expediter
      Sep 29, 2007
      286
      135
      Ratings:
      +13 / 0 / -0
      Maybe take the rotors off and have them turned or at least checked. The best of companies make mistakes. Jerry Lee
    • fastman_1
      Arthritic
      Dec 28, 2003
      6,769
      905
      Ratings:
      +10,877 / 12 / -1
      I'm not a fan of anything Duralast.
    • Dakota
      Nov 7, 2008
      5,311
      188
      Ratings:
      +4 / 0 / -0
      Carrier:
      I never run, I walk
      You have 666 posts that is scary :eek:
    Loading...
    Share This Page
