PerfPlusLBC
Re: !!
Greasyshirt, I think I just sent you a PM about buying a turbo from you, thanks for all the help!!
A little history on the issue we are having: The truck is driven daily in Los Angeles on a 150 mile parts run with about a dozen stops along the way. It stopped making boost and the driver limped it to his next stop, I brought him another truck and I drove that one back. I got in and the truck ran fine for 15 minutes, then lost boost - wouldn't go over 50MPH on the freeway, down to 35MPH up a mild grade. Engine light was on. Stop and restart the truck and the light is out and it now can makes boost again for a few minutes, then light back on and no boost (BTW, truck is a 2005 Hino 238).
I am not 100% sure it's the VNT other than the dealer said it was (and I think that with this many miles on the original the turbo seems like a easy suspect). I am concerned that we will swap the turbo and find out it wasn't the turbo. Found a turbo online from a reputable place in San Diego for $1145. The other shop that I want to have do the install does't have a way to read codes so right now we are guessing if it's the VNT or not. Any thoughts on how to figure that out without being able to read the codes?
Any help appreciated!!!
@PerfPlusLBC Did you ever solve this? Did a new VNT/Turbo fix your problem? I have a 2006 UD2600 (they have Hino J08E engines) which is doing the exact same thing. At first it was just random, but now it is a persistent problem, setting the check engine light right after you start driving (but clearing the light by switching truck off/on).
Dealer scan showed U0073 VNT CAN Communication error as active code when I got it scanned, but it did also have the P0045 showing as an inactive code.
Because of the U0073 VNT CAN Communication error, I've been trying to track down a wiring problem, hoping that maybe it was just a chaffed wire for the communications between the ECU and VNT, but no luck so far.
@greasytshirt I cannot move my VNT rod manually. It is hard to reach on the J08E, and maybe it moves 1/32 of an inch but I think this is just tolerance in the rod joints. Should the manual movement test be more obvious then this? If it doesn't move, but the rods connections don't look to be seized up does this usually indicate a bricked VNT?
Also, does anyone know if the VNT's can be purchased separately from the complete turbo? My turbo is GT4082KLNV - 766758-2 - 17201-E0140 and my VNT is 738265-0039 - B4070-833 DC12V 796 Mitsuba.
The stroke is around an inch.They say the above linked turbo comes complete with the VNT, and the VNT is also covered by their 1 year warranty. At $1450 (after core refund) its a fair savings over the $3300 UD wants for new (of course it is rebuilt not new though).
Also. How much stroke am I looking for out of the VNT? Are we talking 1/8" or 3/4"?
That looks exactly the same. What's the suffix of your engine model (J08E- TC, TV, TA?), and the horsepower rating?Yes I think you are correct about sourcing through Hino, so long as they actually carry the right numbers. Pics attached.
Is there no place to buy just the stepper motor? It feels wrong to replace the entire turbo, when the problem is just this electric motor.
How many miles are on the truck again? These turbos have finite lifespans. @coalminer is one of a few to successfully swap a VNT without calibration issues.
Ive seen where an apparently good working vnt overstrokes when stuck on a random turbo.I can't see there being any calibration issues with this particular vnt. When you remove the motor the linkage snaps all the way up, there is only so much travel in the linkage, if that was a stepper motor, there might be an issue, but there are 3 Hall effect sensors that let the brain know that the motor is moving and in which direction. When I first put mine back together you could tell it was "learning" but it didn't take long and it has been working fine ever since.
450k is about when mine died too, have 525 now still running strong.
That price is within the realm of normal. And yes, the VNT linkage can rust and seize if the truck sits for a long time.I have a 2008 Hino 338 that has 12k miles on it and I bought it new. The engine check light came on and the engine won't run good. Went to the dealership, told me it's the turbocharger. They give me this excuse that it broke down because lack of using the truck. Full of BS. Still, I went forward with the replacing the turbocharger. I got a bill of $3,500'ish. Did they over charge me? This will be the last time I'm buying a Hino.
Hi All. I've been away for a bit, but thought I'd update. I found a remanufactured VNT for the HINO J08E turbos. Bought and installed myself just before a round trip from Phoenix, AZ to Indianapolis, IN. Truck ran flawless. The VNT swap was easy. Installation took me all of 30minutes (disassembly took a bit longer since it was the first time I've done the job.) I don't think there are any calibration issues for this type of VNT. As @coalminer mentioned. The VNT has sensors inside, which teach the computer where it is, and it goes from there. I'd say any overstroking would be do to improper physical stop settings on the turbine control arm, not the VNT controller.
I purchased my reman VNT Controller here: http://www.superiorturbo.com/product.asp?Part_ID=32293
The unit itself is actually remanufactured by this company: http://e-reman.com/products/turbo-actuators/
If I have any problems, I'll try to report back here, but so far so good.
