The attached ATF analysis was done on virgin (unused) Febi/Bilstein ATF, which meets the Mercedes-Benz 236.12 spec which is required for Sprinters. The ATF is blended by Pentosin, and is said to be (by Europarts of San Diego, who sells it) the same fluid which Chrysler offers under the Mopar brand.
The purpose of having an unused sample analyzed was to provide a baseline against which analyses of used ATF could be evaluated. (Note, I believe Chrysler has now come out with a 236.14 spec which is designed to be used in the newer 7-speed automatics - since that fluid is likely of a different composition, it can not be evaluated against the analysis for this sample)
Please note the acidity of this fluid (TAN, or total acid number)
