auxiliary battery = spare battery.
It's isolated.
Typically (OEM at least) they are connected with a relay - a large electro-magnetic switch, very similar to the "starter solenoid" used on (old) Fords.How do they isolate them?
How do they isolate them? I have a Ford diesel and they are connected, at least I thought they were when I looked at the wiring.
When charging voltage is present, the relay ties the aux battery to the starting bat and alternator for charging. Once the vehicle is shutoff, the relay opens, preventing discharge from the starting battery while the auxiliary battery is used.
OK thanks, good deal now I just have to figure out which one is the auxiliary battery and hope I lucked into hooking my inverter wires up so I can use it.
Did you buy the van new? If you did and haven't added an isolater, then they're both cranking batteries tied together. If you bought it used, someone may have modified it. I'd recommend leaving both batteries tied together. When it's cold you want that cranking power. My van had one battery under the hood and one on the frame, when they went to the 6.0 they put them both on the frame. I hooked my inverter to the one under the hood and just made sure to start it often for some charge. An auxiliary is a real good idea, no worries.
Star,Did you buy the van new? If you did and haven't added an isolater, then they're both cranking batteries tied together.
So just because there are 2 batteries it doesn't mean that 1 is an auxiliary? Is the auxiliary battery the OP talking about just specific to Sprinters then?
