chefdennis
Ok, if you were going to build a truck under 10,001 gvw and were not concerned about cost or payments what would you build? My concerns are not in the powertrain, gas vs diesel, 4spd od vs 6 spd trans...but more to the box configurations. To be totally honest, this is more for comfort then the freight capacity...
My thoughts are a 138" WB 9900 gvw GMC Cut-away chassis, bob the frame rails so that there was no more then a 3 ft overhang of the inside cargo floor from the centerline of the rear axle. Then have the frame stretched so that a 18 foot long 78-80 inch high box with straight walls, no body curves at all could be installed. With the light weight composite materials available today I don't think there would be a great weight loss from this box and still leave a good gvw for freight. My thinking is 2500-3000 lbs for freight...I know and I am not worried about the weight of me and my personal stuff... 3000 lbs migh be on the high side, i am not really sure at this point, but again this is more for comfort not weight capacity...
The 18 box would allow for a fixed wall to seperate the cargo area from a 5 ft dedicated sleeper / personal area and a 12 ft cargo area. A cab top airfoil with the top of the cab cut out so one can stand up between the seats and a minimal wall between the cab and box open to the sleeper area.
So any thoughts? how would any of you set up a under 10001 gvw truck for your own use?
