Need help deciding on repair
Discussion in 'General Expediter Forum' started by TSXpress2015, Nov 4, 2017.
  1. FlyingVan
    Barefooter
    Aug 24, 2011
    1,519
    280
    Ratings:
    +1,669 / 9 / -0
    Carrier:
    Load One
    Vehicle:
    Straight Truck
    I could legally put around 3200 lbs in my sprinter (low roof, medium length) but I can count on one hand how many times I put 2600 or 2700 lbs in there. If it was more than 2500 I did not want it. Maybe that is the reason that my sprinter still has the original engine, transmission and rear end at 774k miles. Unfortunately, I only drive it once a month to the dump and back so I don't think it will pass 776k before it rusts away.
    • Like Like x 1
  2. Grizzly
    Grizzly Veteran Expediter Owner/Operator
    May 9, 2012
    1,063
    280
    Ratings:
    +1,170 / 4 / -0
    Carrier:
    Multi ....
    Vehicle:
    '08 Sprinter 2500 170"
    I understand heavy loads are the culprit .. but just out of curiosity .. what is your interval for changing the fluid? Had it been changed?
    • TSXpress2015
      TSXpress2015 Active Expediter Owner/Operator
      Sep 26, 2015
      64
      50
      Ratings:
      +88 / 1 / -0
      Vehicle:
      Sprinter
      Just had it done about 8000 miles ago along with my oil change, and tire rotation.
    • Grizzly
      May 9, 2012
      1,063
      280
      Ratings:
      +1,170 / 4 / -0
      Carrier:
      Multi ....
      Vehicle:
      8,000 mi ago? So around 200K? Probably too late, especially hauling heavy loads. Fate may have been sealed by then ....
      I'm not familiar with the 2015 maintenance schedule but my 2008 ncv3 says 180K for rear diff fluid. I usually change mine around 150K ..
    • Grizzly
      May 9, 2012
      1,063
      280
      Ratings:
      +1,170 / 4 / -0
      Carrier:
      Multi ....
      Vehicle:
      btw ... I probably would have gone with the new one from Mercedes ...
    • OntarioVanMan
      Thinking
      Feb 12, 2003
      45,236
      1,205
      Ratings:
      +30,839 / 25 / -2
      Carrier:
      Crossroads..now retired
      Vehicle:
      Sprinter
      At the low cost of reared fluid I changed mine at the same time as the transmission around 50k maybe that was overkill but at 1.2 million miles I guess it worked out for the best
      • Like Like x 1
    • Grizzly
      May 9, 2012
      1,063
      280
      Ratings:
      +1,170 / 4 / -0
      Carrier:
      Multi ....
      Vehicle:
      Now we're talking about 3 different generations of sprinters ...
      What's the interval on rear diff fluid change in yours?
      • Like Like x 1
    • OntarioVanMan
      Thinking
      Feb 12, 2003
      45,236
      1,205
      Ratings:
      +30,839 / 25 / -2
      Carrier:
      Vehicle:
      Sprinter
      I believe but don't quote me...about 70K...? Steady or turtle / flyingvan may know off the top of head...
    • WorldPowerTuning
      WorldPowerTuning New Recruit Mechanic
      Aug 31, 2017
      2
      1
      Ratings:
      +0 / 0 / -0
      There are 2 rear end ratios on the sprinters a 392 and a 411 if i remember correctly. The TCU will need to be updated if you swap them.
    • geo
      Bashful
      geo Veteran Expediter Charter Member Owner/Operator US Navy
      Nov 30, 1999
      2,524
      265
      Ratings:
      +700 / 3 / -1
      Carrier:
      ceva retired
      Vehicle:
      Sprinter
      what I have found out over the year's you have some shippers who try to put more on a truck than It can carry doesn't matter the unit , some try to over load, and cut down on paying for the right unit. so you have to know your unit to make sure you don't over load it
      • Agree Agree x 1
    • DollarSign
      Wisdomatic
      Jun 27, 2011
      2,344
      380
      Ratings:
      +2,665 / 4 / -0
      Carrier:
      Load One
      Vehicle:
      Sprinter
      I change my transmission and rear end at every 100K. So far no problems at 405K.
      • Like Like x 1
    • DollarSign
      Wisdomatic
      Jun 27, 2011
      2,344
      380
      Ratings:
      +2,665 / 4 / -0
      Carrier:
      Load One
      Vehicle:
      Sprinter
      I've been doing some thinking on this and since your van is a 2015 I would agree with others and went with the new one. I know it's $8500 but look at the long term.
      I've got a 2012 and I'm already in decision mode. If engine goes, transmission goes, rear end ect. That's basically what a new strip down Sprinter cost. I've thought about piecing it out meaning buying one thing a year and keep the same van. Who knows as it's not been determined yet. Hope it's not for a few years LOL.
      • Like Like x 3
    Loading...
    Share This Page
