I have a scientific theory that makes more sense to me than all Al Gore’s theories do. I have concluded that this very well could be the solution to global warming. If electric bulbs suck dark, and it appears they do, they must surely suck cold too! We can shut down the carbon polluting furnaces because they won’t be needed after electric bulbs suck up all that dark and cold. We're saved!!!
For years it has been believed that electric bulbs emitted light. However recent information has proven otherwise. Electric bulbs don't emit light, they suck dark, thus we call theses bulbs "dark suckers." The dark sucker theory proves the existence of dark, that dark has mass heavier than that of light, and that dark is faster than light.
The basis of the dark sucker theory is that electric bulbs suck dark. Take, for example, the dark suckers in the room where you are. There is less dark right next to them than there is elsewhere. The larger the dark sucker, the greater it's capacity to suck dark. Dark suckers in a parking lot have a much greater capacity than the ones in this room. As with all things, dark suckers don't last forever. Once they are full of dark, they can no longer suck. This is proven by the black spot on a full dark sucker.
A candle is a primitive dark sucker. A new candle has a white wick. You will notice that after the first use the wick turns black, representing all of the dark which has been sucked into it. If you hold a pencil next to the wick of an operating candle, the tip will turn black because it got in the way of the dark flowing in to the candle. Unfortunately these primitive dark suckers have a very limited range. There are also portable dark suckers. The bulbs in these can't handle all of the dark by themselves and must be either emptied or replaced before the portable dark sucker can operate again.
Dark has mass. When dark goes in to a dark sucker, friction from this mass generates heat. Thus it is not wise to touch an operating dark sucker. Candles present a special problem as the dark must travel into the solid wick instead of through glass. This generates a great amount of heat. Thus it can be very dangerous to touch an operating candle. Dark is also heavier than light. If you swim just below the surface of a lake you will see a lot of light. If you swim deeper and deeper you will notice it gets slowly darker and darker. When you reach a depth of approximately fifty feet you are in total darkness. This is because the heavier dark sinks to the bottom of the lake and the lighter light floats to the top.
The immense power of dark can be utilized to man's advantage. We can collect the dark that has settled to the bottom of the lakes and push it through turbines which generate electricity and help push dark to the ocean where it may be safely stored. Prior to turbines it was much more difficult to get dark from the rivers and lakes to the ocean. The Indians recognized this problem and tried to solve it. When on a river in a canoe traveling in the same direction as the flow of dark they paddled slowly so as not to stop the flow of dark. When traveling up against the flow of dark they paddled quickly so as to help push the dark along it's way.
Finally we must prove that dark is faster than light. If you were to stand in an illuminated room in front of a closed dark closet then slowly open the closet door you would see the light slowly enter the closet but since the dark is so fast you would not be able to see the dark leave the closet.
In conclusion, I would like to say that dark suckers make all of our lives much easier. So the next time you look at an electric bulb, remember that it is indeed a dark sucker.
