Extra battery
SoG
So I installed an espar d2 heater and when it's working along with my small fridge which both plug into an inverter sure puts too much pressure on my battery. I want to get an additional battery and run it to my car battery. Question I have is where do I get and how I install a switch so that extra battery I'd active only when I want it to be? Like whenever I am ready to use my heater. Any input is appreciated!
brokcanadian
I've used the hillbilly method for 12 years.
2 walmart deep cycle group 31 marine batteries (cheap, can be charged by your alternator) and a cutoff switch with a big red plastic key.
I wire to my van starter battery for charging, and disconnect for parking so I can use my fantastic fan and fridge
Google diagrams to wire for 12 volts. You can use 1 or 2 true deep cycle, but you'd need a proper dc to dc charger or that expensive deep cycle will die early
Reactions: SoG
SoG
I was thinking of putting the same kind of battery that I have under the hood into my cabin just in case something happens to my main one, I have a spare. That cutoff switch, what's it looks like and where did you buy it?!
brokcanadian
https://www.amazon.ca/002843011-Rating-Battery-Master-Switch/dp/B0000AYAFE/ref=asc_df_B0000AYAFE/?tag=googlemobshop-20&linkCode=df0&hvadid=292963445506&hvpos=1o3&hvnetw=g&hvrand=11851898964846926594&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9000747&hvtargid=pla-567204018896&psc=1
Key left on with no battery draining devices used gives your battery a boost in winter
Reactions: SoG
Battery isolator is automatic, instead of a manual switch, but either will work.
The chances are the battery under the hood is a starting battery It a spare starting battery is really only good for being a spare starting battery. It's useless as a deep cycle house battery.
Reactions: SoG
SoG
Starting to realise that! Going to look into a deep cycle battery. Gotta figure out how to hook it up as well! I am sure there is stuff on YouTube! Thanks
guido4475
Battery Disconnect Switches at Summit Racing
I swear by Interstate megatron plus batteries. But, I do have a Oddysey battery for a secondary battery. It's the 2nd one in 8 years. I wont spend that kind of money again for a battery, but will go with an Interstate battery ( I see Tractor Supply has Interstate deep Cycles for 119.00) as a second battery. I prefer just a standard simple and dependable battery switch as well. I rarely switch it off. I have a Honda EU3000 and a battery charger/maintainer hard wired to the second battery that keeps both batteries charged, and runs off of the generator. The battery charger/maintainer is automatic, and turns on when I start the generator. Simple. $65.00. Cheap. No inverter. That's what my Honda is for. It must have over 35,000 hours on it. I use it like it was Intended to be used. Change the 18oz of oil every Sunday. I'll most likely get a new one this spring. But this onecwont die. Worth every penny.
TFTN-one3B
US Marines
Something you also might want to consider is changing out your alternator to a higher amp output if charging two batteries. Charging both with a stock one will work, but it will be harder on it, leading to it going failing quicker .
Solar
Just to answer the op, why don’t you use jumper cables to connect to that battery, so when you want it disconnected, just take off the jumper cables?
guido4475
Never had that problem most likely because I use a battery charger/maintainer to keep them charged when the van is off and the generator is running.
guido4475
Why not do it right to begin with and run proper mounted/gauge cables to begin with?
Reactions: RoadTime
Solar
Because the op wants to disconnect.
SoG
I dont have a generator. Just the main battery under the hood and one of those yellow inverters.
Reactions: Solar
guido4475
Isnt that what a battery dis-connect switch is for? Why half as* something like that to begin with?...lol.
Reactions: RoadTime and Solar
Solar
lol
Treadmill
lol
I just like to live. Lol
Reactions: Solar
