what are the average per mile rates for LandStar Express America?
Discussion in 'General Expediter Forum' started by HaulTow, Jan 16, 2018.
  1. HaulTow
    HaulTow New Recruit Owner/Operator
    Oct 10, 2017
    27
    5
    Ratings:
    +1 / 0 / -0
    23' box
    solo
    yes lift
    yes hazmat
    yes canada
    dunno ALOT truck gvwr 48000
    • Like Like x 1
  2. beachbum
    beachbum Veteran Expediter Owner/Operator
    May 24, 2011
    968
    170
    Ratings:
    +410 / 2 / -0
    Carrier:
    Landstar
    Lift gate a big plus at Landstar. More freight choices. Plan on a hard first couple of weeks. That said, when it’s all said an done, this is a great company to work at.
    • Like Like x 2
    • Greg
      Greg Expert Expediter Owner/Operator
      Apr 5, 2014
      868
      120
      Ratings:
      +418 / 1 / -0
      Carrier:
      Landstar
      Vehicle:
      Straight Truck
      Treadmill, beachbum, and TeamCaffee are steering you straight. I run solo @ LEA and it is a great carrier for a self starter. They will not hold your hand, there is no central dispatch, so it is up to you, as an owner operator to run your business as you see fit. Be proactive. You are starting a new business, treat it as such and you will do just fine. Make sure you understand that the shipper is not your only customer, agent (broker) relations are key.
      Best of luck to you
      • Like Like x 3
    • Steady Eddie
      Oct 31, 2004
      4,858
      455
      Ratings:
      +4,355 / 5 / -2
      Carrier:
      Load One
      It want be long he will have to change his screen name to: HaulTowTravels
    • HaulTow
      Oct 10, 2017
      27
      5
      Ratings:
      +1 / 0 / -0
      so much to learn, i have no idea what your talking about what add "travels" to my username? I was traveling before...
    • HaulTow
      Oct 10, 2017
      27
      5
      Ratings:
      +1 / 0 / -0
      I am a self started and owned a fleet of trucks before at the camper hauling gig. You say "no central dispatch" what does that mean? I am familiar with central dispatch and assumed this is no different... with central i had to call the brokers, negotiate price and terms, and deal direct with clients... this is WORSE? or hopefully better?
    • Greg
      Apr 5, 2014
      868
      120
      Ratings:
      +418 / 1 / -0
      Carrier:
      Landstar
      Vehicle:
      Straight Truck
      At many ( most?) Expedite carriers, you contact the dispatch dept with updates and availability. This is not how LEA works. While there is an operations dept @ headquarters, they do NOT provide you with loads. Each agent "dispatches" each truck on their loads, if you agree to the terms of the load(s) offered.
      • Like Like x 1
    • HaulTow
      Oct 10, 2017
      27
      5
      Ratings:
      +1 / 0 / -0
      isnt that how central dispatch works? what do you mean each "agent" dispatches each truck...who are the agents? dont i get to cherry pick loads from a general board offered by the agents? I am realizing there is a learning curve to this.
    • Greg
      Apr 5, 2014
      868
      120
      Ratings:
      +418 / 1 / -0
      Carrier:
      Landstar
      Vehicle:
      Straight Truck
      Yes, there is a learning curve.
    • Greg
      Apr 5, 2014
      868
      120
      Ratings:
      +418 / 1 / -0
      Carrier:
      Landstar
      Vehicle:
      Straight Truck
      • Like Like x 2
    • HaulTow
      Oct 10, 2017
      27
      5
      Ratings:
      +1 / 0 / -0
      I just learned my truck can haul 20,000lbs. is that good, bad, or average? I have a drop axle that helps add that weight. Also what should i register it for? origional sticker says 33,000 gvwr ...truck weights 26,000 empty and the tag drop axle adds 13,500 lbs of lift. The stickers on outside of truck say 48,000 GVW. Sorry its been a while since i hauled and a bit rusty at this, and MUST register/plate the truck tomorrow and want to get the correct plate.
    • BigStickJr
      Dec 23, 2006
      2,544
      455
      Ratings:
      +2,643 / 15 / -1
      Look at door jamb.
      Probably a 12,000 steer axle.
      Figure 34,000 on rear for 46,000.
      48,000 is probably only s few bucks more, so that’s what I’d plate it at.
      That doesn’t allow you to exceed the 12/34 but there are states that allow more than 34,000 on a tandem.
      I wouldn’t get too close to that gross until you’ve scaled a few loads so you know how to distribute the weight.
      • Like Like x 2
    • HaulTow
      Oct 10, 2017
      27
      5
      Ratings:
      +1 / 0 / -0
      Isnt 22,000 lbs the most i can carry if truck weighs 26,000? Truck has a gvw of 48000
    • BigStickJr
      Dec 23, 2006
      2,544
      455
      Ratings:
      +2,643 / 15 / -1
      You cannot exceed any axle.
      Probably 12,000 on the steer.
      And 34,000 on the rears with axle down.
      46,000 minus 26,000 is 20,000 payload.
      Does the 26,000 include you, full fuel tanks, and unloading equipment/personal stuff.
      Liftgate usually requires pallet jack.
      I’d start at 16-17,000 and see where it goes.
      Typically your heavier loads will be your cheaper loads.
      I seldom had Over 5,000 lbs in my 22 foot reefer.
      Somebody with a similar truck, hauling less specialized freight than I hauled , can probably give better advice.
      • Like Like x 1
    • HaulTow
      Oct 10, 2017
      27
      5
      Ratings:
      +1 / 0 / -0
      that is very helpful to know! surprised to read that the heavier loads pay less. Last question which is really starting to get off track but what do i need for loading the load, and securing it? How much physical work is needed to load and unload? Do i drive forklifts? Do i load and unload everything? what so i use inside the box to make sure the load is secure enroute?
    • BigStickJr
      Dec 23, 2006
      2,544
      455
      Ratings:
      +2,643 / 15 / -1
      Generally not too labor intensive.​
      No forklift driving.
      If the forklift driver is abusing your truck you’ll generally say I’ll help you, drop the pallets at the door and I’ll load them with my pallet jack.
      You’ll need etrack. The metal rail bolted to wall with slots every two inches.
      I recommend one 2 inches off floor to grab pallets, one at 1 ft, 2ft, 3ft, and maybe eye level.
      This is more than a lot of trucks have. The more you have the better you can secure and the easier your job will be.
      I had six or seven rows in my last truck.
      Then you need some Load bars that fit into etrack , 6 minimum, and straps. 12 & 20 footers are the more common. 6 of each.
      If you’re going to run west, a dozen or two moving pads to haul slot machines. And grab a dozen plastic corner protectors.
      I recommend New Haven Equipment for pads.
      They’ll also have bars and straps.
      Good Luck.
      And buy a good quality pallet jack.
      • Like Like x 1
      • Winner Winner x 1
    • HaulTow
      Oct 10, 2017
      27
      5
      Ratings:
      +1 / 0 / -0
      you know you guys really are pretty helpful in this forum, i am impressed for what little its worth. Wonder if there is a youtube video on this. Do they cart everything into and out of the the box? Do i do all of that? What are "load bars"? (yes i'll use google and try to research). 12 and 20 foot what? I only have experience basically hauling and strapping cars on a flatbed. Where else can i buy moving pads? (buy 24 of them?) yes i'd LOVE to haul slot machines!! I heard they pay well and i plan to run west as much as i can. Again thanks for your advice, all of you guys. Perhaps I will visit her more often and try to give back with my own accumulated advice.
    • BigStickJr
      Dec 23, 2006
      2,544
      455
      Ratings:
      +2,643 / 15 / -1
      Securement is a bigger issue at Landstar than other carriers than what I hear.
      A weirder assortment off odd freight.
      Less forgiving than other carriers over simple violations, from what I’ve been told.
      The is really no excuse for a professional to get a securement violation.
      If you want PROFESSIONAL PAY you must perform like a PROFESSIONAL.
      • Like Like x 3
      • Sad Sad x 1
    • BigStickJr
      Dec 23, 2006
      2,544
      455
      Ratings:
      +2,643 / 15 / -1
      12 & 20 foot straps to hook into the etrack.
      Different customers have different procedures.
      Typically they’ll load and unload you unless a pallet jack is requested. A liftgate required usually means no dock. No dock often means no workers. Expect it to be on you.
    • Greg
      Apr 5, 2014
      868
      120
      Ratings:
      +418 / 1 / -0
      Carrier:
      Landstar
      Vehicle:
      Straight Truck
      Google:
      Decking beam or shoring beams
      Moving pads - thicker is better and worth the extra cost
      12 and 20 ft e track straps
    Loading...
    Share This Page
