RLENT you got a link to the companey that makes the by-pass?
Dan,
The company that makes the Motor Guard filter housing is here:
Motor Guard: Air Management
The unit that I am using is an M-30 - which is ideal because the inlet and outlet are plumbed thru the bottom (which makes it self-draining and very clean when you go to change the element)
When Motor Guard developed them originally, back in the '50's I think, they were designed to filter lube oil (hence the name - Motor Guard), possibly air as well.
Later on, after the founders retired, the new guys that took over running the company didn't want anything to do with lube oil filtration and marketed them strictly for air filtration.
They are currently marketed by Motor Guard for air filtration only - auto-body (paint spray-guns), industrial (plasma cutters), and medical. Basically anywhere really clean air is needed - but they will filter liquids just as well.
The current air filtration units, have some parts (plastic) inside them, as well as an epoxy coating, that makes them unsuitable for use in hot lube oil without modification.
The guy I bought mine from has been a dealer for Motor Guard for a long time. He buys the current model from Motor Guard and replaces the plastic internals with metal components, and removes the epoxy coating. His name is Ralph P Wood, and he's being doing bypass filtration since the '60's. Really nice old guy - and does it pretty much because he believes in the idea ..... certainly not for the money (he's probably lucky, if at the end of the year, he hasn't lost money)
Ralph doesn't currently have a website (it used to be
www.bypassfilter.com and you can look at it thru the Way Back Machine -
waybackmachine.com)
The corporate dikwads at Motor Guard didn't like him using their name on his website and had their attorney send him a letter, telling him (an old man in '70's, suffering from cancer at the time I believe) to take down the website ... jerks ....
Anyways, you can reach Ralph @ 940-458-4536. That's his home phone (in Sanger, TX) - so be mindful of when you call. Jerene, his wife, will probably answer and she'll have to go round up Ralph from wherever he's tinkering at the moment.
There is another company -
Frantz Filters Manufactured by We Filter It! Inc - Oil, Diesel and Gas Filters - that makes a somewhat similar filter (in that it uses a single roll of TP as the filtration medium) - nothing wrong with it as far as I know .... it uses a steel can and I believe an aluminum base.
The Motor Guard is an all aluminum, cast housing. From what I can see, I think the Motor Guard is probably less messy to change (as in none) And anyways, Ralph likes them better.
Either unit will cost you around $150 or so.
These two companies aren't the only games in town as far as bypass filtration goes - there are plenty of others. They are two that offer a filter which uses a common, readily-available item, that is cheap as the filtration medium - rather than proprietary filter elements that are expensive.
Anyone that wants a real education on bypass filtration (and all matters oil) might want to go over to the BITOG site (Bob Is The Oil Guy) and spend some time reading the Bypass Filtration Board in the Forum.
