On the earlier Sprinters and probably on the newer ones we have a prob with it keeping temp in the cold weather in slow traffic and idling. I've found by setting the heater temp control to the top of the blue(cold) or in the middle of the white (basically half way) I could keep heat coming out of the vents and it did not pull all the heat out of the engine. If I turn the heater setting up to the red zone it pumps out nice heat but also sucks it out of the engine in low rpm. So the above worked for me and once rolling and rpm over 1500 I could increase heat setting to get more warmth if required.
Not sure this works in other buggies as it don't seem to in the gm. Have to have the heat set higher to maintain heat.
Rob
Rob
