I must be cursed cause this **** Sprinter keeps breaking down. So did a run to South Carolina, started losing power on the way. Nothing really bad, I had it on cruise control and all of a sudden the cruise shut itself off. Got it back up to speed and tested cruise, it worked again. But every time I went uphill I could put gas pedal almost to the floor before it would get up to speed.
Got to South Carolina, unloaded and looked under hood and saw oil running down side of engine. Took it to Freightliner in Columbia and after a week of waiting they said it was Turbo (I did hear the wooshing noise of air so thought that might be problem) so had that replaced, and knew I was overdue for fuel filter so changed that too, since that caused me to have low power a year ago.
$2200 later Freightliner tells me Sprinter has really low power now. I come by to test it and it is 10 times worse than it was when I dropped it off, so no way I can drive it home to my mechanic. Any ideas what this may be? Fuel pump was already replaced 11 months ago and I'm at wit's end
