Hey all,
I'm looking to buy a cargo van or sprinter. Would you guys recommend any particular make or model the for cargo van or sprinter. Also, what would be a good year and mileage on the cargo van or sprinter?
Any feedback is appreciated.![]()
With the Ford's and GMC and Chevy's I am more worried about the mpg than anything else. Right now how the prices are with gas, and most of those being V8 well above 4.0L it is tough to keep them running all the time.
On the other hand, not that I am limited on cash, but Sprinter's do cost money however they are better with mpg and more cargo space/comfortable.
Its a tough choice.
Keep in mind only the pre-07 sprinters will you have MPG's advantage...the 07 and up on the van level of MPG's..
and diesel is more expensive then gas...advantage van...like Cargomax and others...
I'm looking hard at the retired u-haul single wheel 1 ton gm with a 10 foot box. Under 10k gvw. Around 110k on them and 6500 to 8000 asking price. Can buy a lot of gas with the cost savings over a new splinter.
Just wish the box was 12 feet to leave room for a nice sleeper or 3 skids.
Sent from my PC36100 using Tapatalk
Cableguymn wrote:
While you have to do what you feel is best for you, I wouldn't touch a 10 ft cube....as was said, there are used 12 ft'ers out there, you might have to travel a bit to get one, but over time, you will regret that short box....
I noticed penski has a bunch listed as 10k gvw but they are dual rear wheels. Most of those I have seen are 11k plus. I don't need/want a c unit or to deal with log books.
The company I am signed with is a last mile company. 99.9% of what we haul is from/to a local terminal or the airport to the drop less than 300 miles away. A place to sleep in the truck is for the .1% but I am also thinking down the road. If I go with a dual wheeled truck it won't fit between the wings of the smaller cargo planes I load and unload.
Unless your talking a 12 foot single wheeled van. However I can't think there is much payload capacity left in one that long.
I've though about a splinter however I can't sleep the short way in them comfortabily. I am just to tall. Plus most seem worn out or over my current budget for the truck.
I'll keep saving and see what comes up. As long as the 02 keeps going I am not pressed to get something.
if your making out ok now...run it till it drops...and Good Luck...
A SRW Chevy / GMC will have a 64-6600 lb scale weight EMPTY...at 9900 lbs GVW..depending on how much your "stuff" weights, you will still have over 2500 -3000 lbs available for freight...
There are 12 ft SRW cubes out there and available..but as i said, you might have to travel to find one...but they are out there...they might not be yellow "penske" trucks, but they are available used...
Now, all of that being said, if you are for sure staying with your current carrier, and have no thought or desire to move on to OTR Expediting, then that certainly changes things..if a 10 ft'er works, and you simply "want" a newer van..go for it...we aren't running the way you do...so it that situation, your experiences don't work...
