guido4475
I use Zep products fast 505 commercial degreaser. Strong stuff. Don't let it dry.H
Hydrogen Peroxide, 50/50 w/water to start, stronger if needed. Wet and let soak a few times then a mild soap and a pink scotch bright pad.
Is that a Kentucky cut to size steak chub on the right !!!!!!!!
I agree! When you have the right people in place it makes the job easier and also makes the company "Load One" look GREAT! Therefore more companies will/go with Load One.We call that the hard working men and women of Load One executing logistics at a high level of proficiency!!!!! Or luck. The first one sounds cooler![]()
H
If you go to flightradar24.com you can see a lot more info about the flight, like the actual location, altitude, speed, etc, what kind of plane, registration number, even pictures of the actual aircraft.That's actually pretty cool to see the status of the flight like that.
All the information a well-informed terrorist needs for a shoulder-fired FIM-92 Stinger.If you go to flightradar24.com you can see a lot more info about the flight, like the actual location, altitude, speed, etc, what kind of plane, registration number, even pictures of the actual aircraft.
He's a modThat's wild. But not as wild as thinking I was in the wrong forum section.
FlyingVan, when did you come over?
Welcome aboard![]()
Oh cool. Welcome aboard Chip!His profile says Load One Straight Truck![]()
Neat but dangerous, lolThat's actually pretty cool to see the status of the flight like that.
