how to insulate
desdes
hey all, i have a 2007 E250.i am getting ready to insulate it(cool in summer,warm in winter)i dont no where to start,i would like to hear every possible option.thanks
Get 1" foam board, 3M spray adhesive, canned foam, some Liquid Nails or Lock-tite caulk adhesive, a calk gun, scissors, and some of the silver Reflectix bubble pack insulation for Lowe's. Also get some of the silver sealing tape which will be found over near the paints, but don't get the foam-backed tape for plumbing, just the silver foil tape with no backing. You'll need way more of everything than you think you will, and it'll take about 5 days to do ir properly.
Insulated the walls, ceiling, sliding and rear doors. Be careful of the driver and pasenger doors, cause it's (a) more trouble to insualte than it's worth and (b) you'll end up screwing the window track up if you try, so don't.
Cut the foam board to fit as many of the voids as possible. Use the canned foam or the Lock-tite to hold the foam boards in place. Then fill in the rest of the voids with canned foam. The use the spray adhesive and the Loci-tite to glue the Reflectix to the walls, ceilings and doors. You want no exposed metal, or as little as possible, since the metal will act as a heat sink. Make sure you seal every Reflectix seam with the foil tape.
Another option is to take it to some place where they'll blow in the foam insualtion into the walls, ceiling and door panel voids. Should run you about $500 for that, which is about what you'll pay to do that part of it yourself, anwyay. After the foam is sprayed in, do the Reflectix thing.
Sprinter
Ford before insulation, and after (think Jiffy Pop)
Jack_Berry
Moderator Emeritus
i'll bet it is really bright in there with a couple leds blazing.:D
i used two sided industrial velcro and applied to the upper part of the walls. then unrolled the reflectix and attached to the velcro. in the ford there are spots along the wall on either side to screw in a 1x2 or 2x4. you can do that and then appl 1/4 paneling over the reflextix. or you can appl the paneling direct and use self tapping screws to screw it into the ribs.
the roof was harder and my wife used her nimble fingers to wrap tie the reflectix to the ceiling bows. hope to finally get the ceiling paneling up this weekend.
guido4475
I would leave the reflectix bare, throw in a strobe light, even a disco ball, make the floor light up and youre in business!!. I may end up doing mine this fall.Great ideas though. Thanks!!
Dakota
Don't forget the eight track player and hi-fi sterophonic system
moose
there is a solar vent here that is wire free. you can fine it at jc whitely for around $10 less
We now have a wind mill powered vent ,
you turn it just fast enough to make the first few volts , then it kick the vent on .
you steer the vent to the wind mill , the wind from the vent will power the wind mill ,
that will make just enough power to for the vent to run on ...
It is sponsor by the EPA , under the clean energy act .
it is free , you already payed for it.
click on the link below to claim yours :
ExpeditersOnline.com Expedited Trucking Owner Operator Careers and Truck Sales
