drug and alcohol testing
jezzy
im looking to start expediting and wondering what kind of tests are done for driving a cargo van. they tell me i need a chauffeurs license and need to pass a physical. what are the tests they do some say non-dot and some say dot what are the differences and do you have a urine or blood tests. where do you get the tests at? ive talked to express 1 panther ctx expressway etc. thanks hope to see ya on the road.
jasonsprouse
No such thing as a chaufers license anymore, at least on the federal level. You don't need a CDL to operate a cargo van, unless you will be transporting Haz Mat. Some states may issue special licenses to light duty commercial drivers.
You will need a DOT physical to get a DOT medical card. A drug test is not required for below CDL driving, although the carrier will certainly require a pre-hire test.
rmctt2
Yes , you will have a pee test !
From what I understand most drugs stay in your system for up to 2 months ! ( Sometimes longer, depending on the drug )
Alcohol I believe it is 1 month ( please do not Qoute me on that ) !
Also, some testing have instaneous results...
I applied for a job at a Hospital in Spartanburg, SC.. They had me pee test and they had a machine there that was 99.99 % accurate and they knew the results in 10 minutes ! I read some of the info on the machine while waiting for the resluts !
Have to list everything you have taken too !
I laughed becaused the only thing they found was Aleeve in my system..
I have not had any alcohol or illeagal substance in over 23 years !!
Thank God !!
Good luck
rmctt2
jasonsprouse
If there is any "concern" about what the results of a test may be, keep in mind that you will most likely also be subject to randon, unanounced drug testing. This is standard for any driving job.
kwexpress
KW Express
o/o till i die
its more than likely it federal guidlines.you will have a test before you start and be subject to randoms.
Tennesseahawk
Anyone who is "worried" about taking a drug test should find a different line of work. This isn't professional sports where you might get a suspension and a slap on the wrist. It's basically a one-and-done deal.
-Vampire Super Slooth Trucker!!!
Jazzy,
If you live in Michigan, you will need to take your chauffeurs license test first and then the CDL.
Express-1 will be one of the few that will accept a chauffeurs license instead of a CDL, all others will need a CDL.
