Doors
dpea9
I need a new set of barn doors on a D-Unit. I believe the box is a US Van Body. Does anyone have a suggestion where to go for a set of doors?
x06col
Any trailer repair shop can build you doors.
Broompilot
One of the biggest failures is Water Leaks in thru the top and does not escape out the bottom due to trash etc.. Clogging the drain holes in the bottom.
Thus next freeze, water expands and so do the doors once that happens they are trash.
Also over time they can begin to bend so much that a tight seal is not possible. Replacement is the probably the best option, one can temporary fix them but in our business if this freight gets wet your gona pay for more than just a new set of doors.
Inpect those doors, and if you have drain holes keep them clear. The earlier you see a bow or bend in those doors the cheaper its gona be to fix.
dpea9
The doors are rusted and rotted out around the hinges. Does anybody have a shop they would recommend for repairs?
As mentioned, any good trailer place should be able to fix them. You could also call around to the companies that are specific dealers for your box.
owner
22 years
PantherII
EO moderator
