smitty8567
I have a comfort master APU unit. I turn it on and it will run for about an hour of running then it will shut down and show "temperature reading high". Do you have any suggestions and how to solve this problem.
How many watts does anyone need for an APU? Why not get a Honda 9000 watt unit and set it and forget it. And why does an APU unit have to be hooked into a water supply and all that, seems to be way to much engineering imho.
What are the advantages of being plumbed in?
Sent from my DROID RAZR using EO Forums
It acts as an engine warmer. Some prefer that to engine block heaters. One less radiator to leak and maintain. I don't like it. I have had too many problems due to leaks. To each his own.
The new comfort pro sold by Carrier dealers has a stand alone unit with a larger rad. it has a 6k gen and plug the block heater into the APU.
Or you can stay with the 4k gen set unit and use the truck rad system
The reason for the big new gen is to plug in the block heater
Can you post a link to this unit? No dealers I have spoken to know anything about it.
Must be REALLY new, it is not on their web site yet. Neither Carriers, or Impco's sites
The link is a pdf it will download to your phone nite open a site. Remove the stuff after the. Com to go to the site or go to the link via computer.
Sent from my SAMSUNG-SGH-I717 using EO Forums
