2010 Hino 258 rollback A/C, Radio? Issue, please help. Truck down
Discussion in 'Hino Trucks' started by roadmasterstowing, Jul 12, 2018.
  1. roadmasterstowing
    roadmasterstowing New Recruit Owner/Operator
    Jul 11, 2018
    1
    1
    Ratings:
    +0 / 0 / -0
    Hello
    I have a hino 258 rollback. Truck has 282k on it. While cleaning and doing PM the other day, my driver noticed that the blower motor was really low, he tapped it a few times, and it went back to normal. Then it stopped. Brought the truck to the shop, and the techs replaced blower motor, and now the blower motor is running at correct speed, but no cold air coming out. Switch works, the ac light button is on, and they found that the aftermarket radio is dead. Any ideas?????
  2. greasytshirt
    Dr Pepper Addict
    greasytshirt Moderator Staff Member Mechanic
    Dec 3, 2013
    2,171
    220
    Ratings:
    +734 / 0 / -0
    What year is the truck?
    The AC switches are known to burn out, taking out it's connector and wires at the same time.
    Check both the radio fuse and the room light fuse. Oddly enough, the room light fuse partially powers both the radio and the AC compressor. For a 2008 truck anyway. I'm taking a shot in the dark on the year.
    • Treadmill
      Caffeine Fix
      Treadmill Veteran Expediter Owner/Operator
      Jan 1, 2008
      2,418
      430
      Ratings:
      +3,473 / 9 / -1
      Carrier:
      Load One
      Vehicle:
      2017 Sprinter
      Going by the title of the thread, I believe his truck is a 2010.
      • Zing! Zing! x 1
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,171
      220
      Ratings:
      +734 / 0 / -0
      I missed that completely.
    • Andyinchville1
      Andyinchville1 Active Expediter Owner/Operator
      Apr 21, 2016
      113
      50
      Ratings:
      +32 / 1 / -0
      No AC? NO radio? ....Truck is STILL functional ....
      Go out and make some $$ and tell your helper you won't them charge extra for the free sauna !
      OR
      You could be nice and check the refrigerant level (if it's not properly charged or leaked out), the blower will work but the AC compressor won't turn on to make things cool...
      Good luck.
    • Techmaster
      Techmaster New Recruit Mechanic
      Aug 3, 2018
      25
      3
      Ratings:
      +5 / 0 / -0
      Also the actuator that controls the temperature blend door could be jammed or dead, turn the key on, fan to level 1, turn the temp from cold to hot and carefully try to listen if you can hear the motor moving or clicking if jammed up
    • Hino123
      Hino123 Active Expediter Researching
      Dec 26, 2016
      132
      50
      Ratings:
      +38 / 0 / -0
      Hino trucks actually do NOT use an actuator for the blend or mode doors. Its just a cable operated setup. The heat and mode selector should move freely from left to right. Is the cabin air filter plugged? Is the A/C belt loose or even there?. Did the a/c work before this happened?.
    Loading...
    Share This Page
