There's an LED display on my console, bottom left, that's flashing at me with buttons...does that mean I've got an aux heater or constant RPM switch?
Look behind the drivers side head light below battery. If you have one it will be there with two hoses. Look under left front for intake and exhaust pipes. Or, hit the switch on AC/heater control. It's on the left side cross bar. It will have 3 curving lines with a dot above the middle line. That turns it on and off.Are you telling me i've got an Espar in here or something? I'm trying to look it up but I'm not getting the point of if it's that or this hot water coolant recirculation thingy
Appears to be the hot water recirculation, I don't see exhaust or fuel line, it is behind the left headlight (edit: found a baby exhaust pipe in the front of fender WOOHOO espar!)
I kind o got off topic, tested Tcm with scan tool, shifter works properly but speed sensors in transmission read 0 when drive selected...advice on control board or wiring harness?
It appears to be the connector plate. I wouldn't drive it for many miles, you'll burn it up. This is one item I don't let just anyone do it. Especially those mechanics that have torque elbow indicators. I think a connector plate is around 100 bucks if you buy it online. Www.Europarts-sd.com pick your year a enjoy.
Seeing that gasket, it looks like this thing wrapped around the front of the transmission like somebody wanted to keep a spare or something? Weird
