I went with the gulfcoast product becuase of its design simplicity and suerb ruggedness if youve ever seen one up close youd understand.
I have not seen one first hand, nor have I personally used one - but I have seen the stuff on their website .... I have no doubt that it is quality product. In fact, the guy I bought my TP filter from used to either sell, or work for Gulf Coast I believe.
Having said that when ou use a spinner filter do you still change the oil or do you leave it untill the anylysis sais its bad.
I'd imagine that most folks that use them are doing extended drains and are having their oil analyzed .... one guy I know who ran them on his Class 8 fleet would prototype a new lube oil on a specific individual power unit and come up with a reasonable drain interval and then apply that across vehicles in his fleet which had the same powerplants. If I recall correctly, he was using a drain interval of around 90,000 kilometers, although it may have been more.
Gulfcoast told me they have more than one customer with no oil change in million miles.
Don't doubt it in the least .....
But most of thier customers dont go that long out of habit.
Yeah ... old habits are hard to break .... moving from periodic maintenance to
conditions-based maintenance is a real stretch for some ... especially when it come to oil changes.
They soke very highly of the toilet paper filters but siad theyre caacity is too low for class 7 and 8 eingines
That's entirely correct - unless you ganged multiple units and ran them in parallel ... even at that, the amount of upkeep filtering a sump that large would be significant, I would think.
I was changing my element every 3K to 5K miles on a sump that was around 10 quarts .... it really wasn't too bad, as it only took 5 to 8 minutes to change out the element and wasn't messy if you let the filter drain overnight and did it first thing in the morning. Still, it was a little more than I would prefer .... so we'll see how the centrifuge goes ...
I think the guy I bought mine from has a unit that uses center-pull paper towels .... like you see in restrooms to dry your hands .... I'd imagine one of those would have significant capacity ... lotta cellulose there ...... almost like filtering your oil thru
a log .......
