moose
Here we go again. Deborah Hersman ,head of the National Transportation Safety Board, continue to ignored it's own agency finding of a transportation accident investigation, and push this administration agenda of limiting our freedom by recommendation of needed regulation.
and Thank's god the NTSB is limited to recommendations ONLY.
finely the NTSB published it's investigation of the Nevada truck/train accident.
http://www.ntsb.gov/news/events/2012/miriam_nv/Abstract_Miriam_NV.pdf
as always, NTSB recommendations have very little to do with a truck accident finding, and a lot to do with a predetermined agenda.
despite the fact that they have no idea why the trucker was 'inattentive', they, never the less comes with a long line of recommendation addressing 'distracted driving'.
#6 is a total fabrication !, handheld cellphone ? fatigue ? pain ? - who wright this stuff ?
but what really gets me is the conclusions #12, & the recommendation # 17  . predetermined agenda. !
why ATA, buses & OOIDA ? why ONLY those names have been pulled ?
what about trucks that are unions driven ? teamsters ?, Truck Load associations ? constructions truck drivers ?, dump truck ?,
but the real problem is NTSB failer to understand the operational condition of a truck that crushed into a moving passengers train. NTSB own finding show that most of the break system where not factional, out of adjustment. and that the ABS system was not properly maintained. ABS electric lines where cut, and ABS unit where missing. NTBS own finding show that this was the case with EVERY other rig operated by the carrier.
Hello ??? NTBS??? are you reading this ? you think there's a rezone ???? there's a good rezone. like everyone in the industry will tell you those mandated units are way too expensive and way too under performed to be maintained on a rig that spends most of it's lifespan hauling heavy dirt into a goldmine !
mandating another worthless electronic system to such rig will only result with the new monitoring system getting a same level of maintenance.
at least ABS system are "EOM" (they are not made by the truck/trailer manufacturer, just installed at the time of the vehicle productions), but hose recommended aftermarket gadgets have NO chance what so ever to perform as well as the rest of the truck.
what Miss. Deborah H. would like to see is every truck and trailer been equipped with a complicated unreliable electronic system, that alert the driver when a break unit is not properly working.{#6}. open your wallet, and be willing to be placed OOS.
another problem is that the FMCSA did NOT published guidelines for it's enforcement officers, of how to handle a truck that have a light showing an out of adjustment break unit.
as stated in this report CVSA is yet to do ANY leg work ! those systems needs 1st to be readily available.
this year during 'break week' enforcement blitz CVSA was very clear, for the first time that they will target 'monitoring systems'.
in other words if you have a tire inflated monitoring system on-board, and the light goes red, - you are out of service till you fix the tire! (or the light). same goe's to the break monitoring system. if it's show that the break is out of adjustment, then here is your ticket.
even if this aftermarket gadget is the failing, you are still guilty till prove otherwise.
NTSB - failed.
NTSB - failed.
