chefdennis
Ok, i spend the weekend working inside the can...the roof has a transpart panel that runs the length of the roof. When sitting in the heat of the heat, it gets like a greenhouse inside..the 8000 btu unit helps, but at times it just can't keep up...
If you look at the earlier pictures you can see the translucent roof panel...
So it was time to insulate and cover the ceiling...Here are the pictures to show how that was done...I glued reflextic foil bubble insulation to the ceiling...coverd that with 1 inch form insulation board. I then ran to 7 ft lengths of "hat channel" from the bulkhead opening at the back of the ft seat 7ft back and then attached 1/4 inch luan plywood. I also did some other "wood" work to "straighen out the compound curves in the box to make it easier to finish the ft area., Net weekend i'll cover all of this area, walls and ceiling with a indoor outdoor carpet to finish off the area totally.
Once the walls are finished i'll install the TV and the Max Vent in the roof...The vent was suppose to go in this weekend but, I ordered it a month or so ago...it came and I just let it sit in the shed, didn't bother to open it, (I know what it is and what it looks like) so when i open it the other day, it was broken....so it gets sent back in the morning and i'll install the replacement in the next few weeks..
So here are a few more pictures, in the ongoing build of the Cargo Max...
