The internal mode switch tells it if its in gear, based on pressure in various passages. Metal particles get in switch and cause a connection at bad times.We have a 2010 258LP-10 Flatbed tow truck w/ Allison transmission. It went into limp mode, we were able to get it to a shop next door to us, he is limited on his software, but was able to pull a hard fault code for Shift Solenoid #3 open / stuck. We don't know what the exact code was and we believe it is stuck in 3rd gear.
Wondering if there is a wiring diagram available or any thoughts on what's going on / what to do.
Without having done a bit of research, I'd tell you to replace the IMS, the internal harness, and both filters. Make sure donut magnet is on spin on filter.
