Maverick
Last summer we ran a 2000/2200 (peak) Honeywell for an 8000 BTU Portable Air unit. Setup worked fine, but was not happy with the run time of 4 hours. This combo cycled and ran well on Eco mode....though she kicked up quite often during cycling/compressor running. Cost? 275.00 for the 8000 BTU, and 600.00 for the Honeywell = 875.00 to run adequate air unit in van.
Top mount unit is not an option, as I'm not drilling holes or cutting out the fiberglass top, and we don't need the extra height.
Three ways to go IMV......
1) Live with the 4 hours run time, and adequate.
2) Find a 2000ish low db unit (higher capacity tank) and mount in front of grill.
3) Use the same 8000 BTU air unit (likely, as it works great) and obtain a higher end enclosed inverter unit, with larger tank capacity/run time. The leader here is:
Yamaha EF2400ISHC EF2400iSHC - 2000 Watt Inverter Generator
4) There is a 4th option for running a 5000/6000 BTU window air unit, using the proven Honda 2000i/Yamaha equivalent......but these units are actual 1600 Watt and low tank capacity as well. Not a good answer. Some will say, 5000 BTU will not really cool you're living space, given the placement options.
Need feedback on the potential front mount LOW db unit, potential fuel feed options to the Honeywell set-up, and any acquired knowledge on the 5000 to 6000 BTU window units, using the 1600 Watt proven generators.
Know it's all been covered before, but it's approaching Summer, and maybe worth some updated comments from all angles. Thanks in advance.
