Broompilot
Had a load from Detroit/Denver 9500lbs all flat until Western KS mileage was dissipointing to say the least.
Just put new Steers on (first problem)
Weight balanced like a Pro (even passed CO scale house)
Fuel the same Pilot/& J.
No wind beautiful weather little rain in IN.
Fuel was about 20% below previous tank, only improved about 10% with half that weight back to D.C.
Took the truck in when I got back home had the tires highspeed balanced on the truck. Should have seen it shaking even the rears touching the ground I could put my hand on the rear tires while the fronts were spinning and could feel that shake until they put the correct weights on it.
I also had the tires Trued again (steers) I had this done months ago but had a belt fail in one of my steers all though it was not causing me any problems yet I do not trust bad steers.
So my question is how much difference do you see between loads?
Prior to replacing the steers averaging 10.3 to 9.5 8.8 heavy load with poor road conditions.
After installing new tires 9.2 best all the way to 7.7 that hurt.
