piattteam
Hey all, our coolant system is messing up and hoping to get some help here.
The coolant heats, goes into the overflow tank just fine.
Problem is, the system isn't sucking the coolant back out of the overflow tank, into to radiator.
Runs 10 degrees warmer than usual, but doesn't over heat.
We have replaced the cap, incase the vacuum release check valve was bad.
Thanks all!
Thanks all!
