Blueparrott B250-xt not charging?
DollarSign
Hello everyone! As I was driving to Pa I was using my headset and all working fine. Today I went to go charge it up and Its not charging at all? Any ideas
Sometimes if you rotate the charge plug in the headset it'll start charging. Mine does that sometimes. I think mine has a short in the plug somewhere. Make sure the other end is fully inserted in the 12v socket, too.
BigCat
Check the fuse in the plug that goes in the cigarette lighter too. Mine blew a fuse a while back and I replaced the charger only for another driver to tell me to check it and that was the problem.
DollarSign
Tks turtle and bigcat. Ive got it plug in the wall and left it all night and was hoping it would some how start charging, but it didnt. I tried rotate the plug, different socket. Im wondering if its the battery?
zorry
It can be the battery or your home charger. Try your 12 volt charger.
Order a battery either way. That way you'll have one when you need it.
tknight
Fat fingers and that little battery don't get along ,it's a tight little bugger to change out
tknight
I've had micro switch troubles ,after exploratory
surgery bought a new one patient didn't survive
