Woodworker
I own a 99 Freightliner FL60 (26000 lb) with a 3126B Cat engine. (mileage 344,000).
Two weeks ago, I had a problem when the injector cups leaked, and diesel fuel was pumping into my engine coolant. I took it to a Freightliner shop, where they replaced them. After driving approximately 600 miles, the engine lost power, and the truck was towed into an independent repair shop. I showed them the repair slip from Freightliner, and they were surprised that the oil had not been changed during the repair in case coolant had leaked into the oil
They found that the high pressure pump that drives the injectors had failed, and replaced it.
After they got the truck running, there was a loud squeal in the engine. They pulled the oil pan, and found the #2 rod bearing was bad, and the crankshaft is now bad.
The truck is at J&L Fleet services in Osseo, WI.
I am looking for advice about what is the best route to take to get the truck repaired. Should I try to get my engine rebuilt, find a rebuilt short block, or go with a remanufactured engine?
I am also wondering if not changing the oil during the first repair could possibly be the cause of the present problem.
Any information you may give me will be very much appreciated.
Woodworker
Woodworker
