2007 Hino trans cooler line leaks
Chazman1970
Hello folks, newbie here to the forum. I work as an independent mechanic and I have an '07 Hino 268 with an Allison trans that keeps leaking at the cooler line connection at the radiator. I have replaced the o-rings on both lines several times but the start leaking again after a couple months. Does anyone have the correct size and material information on these o-rings? My local International/Hino dealer is my closest source of Hino parts and they say there is no listing for the o-ring that goes inside the fitting on the radiator. I have tried buna and viton though the viton was questionable as I'm used to them being tan. Any help would be greatly appreciated.
Hino123
Researching
Some Hino’s do not show the trans cooler fitting as being available separately, and others do. To my knowledge they are all the same from 2005-2020. Freightliner uses the same fittings. I keep 2 spares in my tool box. I’ll try to get a fitting number for you Monday.
