Big Truck Where do you fill your water tanks?
jhead64
For those of you with sinks and running water in your trucks, where do you go to refill your tanks?
Reactions: neilblack
NightDriver
We use the RV islands at the J, usually. If we park at a friend's house or an RV park, we'll take advantage of the situation and top the tank off before leaving. We buy in-line water filters in the RV section of Walmart and change them often. No issues so far.
The real challenge is where to get water in the winter. Unless you run frequently in the deep south, you'll find all water spigots shut off to prevent freezing. You can sometimes sweet talk the maintenance guy at a truckstop to hook you up (deserves a tip) to a working spigot. I keep a solar shower bag on hand and when water is scarce in the winter, I'll fill it with warm water in the ladies' room and take it back to the truck to do dishes or wash our hair. It doesn't take up much space and we have to resort to it quite often in the winter.
TeamCaffee
We use TA's at the fuel island and two water filters. One filter is on the hose and the other is between water tank and sink. If there is not water at the fuel island most of the time we can fill at the shop using our water hose. It is harder in the winter any that is how we learned about asking the shops if we could fill our tank.
Reactions: jhead64
TeamHutch
There are a lot of rest areas in some states that have rv dumps and water fill up also. One that come to mind is along the 80 in Ohio at the service plazas. It will be over in the rv parking areas
Reactions: jhead64
