unorthodoxneon
I'm in the process of doing some research on adding an overflow bottle to our trucks. I have an FL-80 with a cat 3126 motor. And i noticed that the way these truck systems are set up that if there is any extra fluid is just purged to the outside and there is no way to bring the coolant back into the system like on personal vehicles. Before i got into this truck someone had zip tied a gatoraide bottle and cut a whole in the top and had the tube go into it. Well i noticed that the coolant system would use this bottle. So i went and bought a Radiator Overflow bottle kit and installed it on the truck and running some test now to see how well it works. I've ran it for a few hundred miles now and notice that the coolant level inside the system has been at the proper level and not needing to filled.
I will be posting some pictures in the next couple days on what it looks like. I think that this is a modification that should be considered on all trucks.
