G
guest
Guest
Deadhead, there is no way that the heater can go out. The gas is continuously flowing from the cylinder to the catalytic chamber, where the combustion takes place. When the gas in the cylinder is exhausted, then the heater stops working . I think what happened is that when you started the heater, you did not hold the control knob in the START position long enough, ie 15 seconds, or you did not move the control knob back to the RUN position after lighting the appliance. Either way, the equipment will only perform well if the operator follows the instuctions poperly. I repeat, once the unit is properly ignited, and the control knob is in the run position, there is no way that the gas can escape without being consumed in the catalytic process, period. Like anything else mechanical, READ the instuctions first. Jim Bunting...
