Since this thread was started in an obvious attempt to get away from the other thread...I'll go ahead and ask some of the same questions here
The links in my previous post are for the most part discussing the repair issues and very expensive parts in the Sprinter DEF system. Below is an excerpt form another thread copied and pasted here:
Point being. It appears the DEF system can get expensive. The B service, even at half the cost, when added to the $200 oil change is going to get expensive. One person mentioned that it cost him $2800 just to replace the tank. But wait, it gets even better. The poster in this thread:
http://www.expeditersonline.com/for...def-system-repair-solution-previous-post.html says that he was into his problem for about $3,000 BEFORE they actually found the problem which cost almost another $2,000 to fix.
But wait...it gets even better still (says Ron
). That is just referring to the DEF system. That's not even the expensive part. The DPF is the expensive part. The same poster in the above linked thread says that replacement of the DPF is about $5,000 and I know that we have seen other discussions on this forum about that exact thing...so it does happen. I do believe that it's less than $5k though. the number I've heard is $4,000 at a MB shop. There are alternatives, but their still not cheap and their not MB approved. Since so many Sprinter owners claim that you must follow MB maintenance recommendations very strictly, I can't imagine doing anything that is not MB approved?
But wait, there is still more
. Proper maintenance of the DPF will likely extend the life so as to avoid those astronomical replacement costs. So I looked online and found a maintenance manual for the Sprinter here:
http://www.mbsprinterusa.com/files/manuals/2012_Mercedes_Benz_Sprinter_Maintenance_Manual.pdf
On page 9 of that manual, it says this:
So, if I understand this correctly, after the 4th service (40,000 miles?) you need to start checking the DPF filter at every service. That tells me that after 40,000 miles they are expecting it to be not a matter of "if" but "when" will you see the $4,000 replacement.
I'm not trying to be difficult so much as I'm trying to get some actual numbers. Anyone who knows anything about '07 or newer Sprinters knows that they can get real expensive to maintain...real fast. The $2 comment ignores that fact completely and totally. I would love to see someone post some actual, real numbers. Not telling the truth about the actual costs to own and maintain a vehicle misleads those who read these forums to gather information and make decisions on a major purchase. Leading them to believe that if they buy a Sprinter, they will not have any costs to maintain it is unprofessional, snarky, and counterproductive to a quality message forum.
