PantherII, Should i run with their plates or mine?
DoubleJ
I am about to put a semi on with PantherII, are there any advantages to running with their plate, or am i better off running my own?
I have this truck on a different fleet than my other 5 semi's, that are only plated for 4 states. Does it cost more to plate and run 48+Canada ?
bigguy1k1
RE: PantherII, Should i run with their plates or m
On the positive side of running Panther's plates you have very little up front cost, $100. And the payments are spread out. On the negative side, Panther owns the plate and keeps it if you terminate.
As far as cost goes, I'm not completly sure but, I think the cost remains about the same whether you plate for 5 states or 48, it's a matter of how they distribute your money.
I would recommend, if money is not an issue, that you get your own plate. Retain as much control over your own destiny as possible.
