Need Help Freightliner M2 106 AC
Limey_Lee
Hi guys,
Can anyone send me a picture or tell me where on earth the low pressure line is on one of these trucks please??
I can see two line under the AC Housing, one thin and one thicker.
Any help much appreciated.
Treadmill
Hi guys,
Try posting this in the Truck section. That's where greasytshirt hangs out.
Techmaster
Follow the lines, eventually you should see the service ports. One port is larger then the other. The smaller of the 2 ports will be your low side line.
Ray T.
Hi guys,
Are you trying to charge the A/C. Low side is the bigger line. Charge ports are on the passenger side under the hood by the frame.
