G
grannytrucker
Guest
Hey guys maybe you can give me some advise. I own a 2003 M2 106 w/Mecedes engine. Have always had it serviced at a freightliner dealer. In December we had an oil change done at a freightliner service center. Had them use our filters/Mecedes, and tried to keep an eye on the tech as much as possible. I found that he hadn't put my filters back on the truck as we had asked and went in to advise service manager of that issue. During that time the tech couldn't get the truck to start so he used ether to get it started. Ever since then the truck hasn't run right. We drove from San Antonio to Clovis, NM and and injectoer went out. from Clovis to Sheveport, LA we had the turbo go out causing the charge air cooler to go out. From Sheveport to Greenville, SC we had 2 more injectors go out. After sitting over the holidays we did a load from Greenville to Indianapolis, IN and the engine won't start unless we held our foot to the floor till it picked up the fuel. Stoops freightliner suggested changing the fuel filters, we did, it ran fine till we started back to Durman NC then the check engine lite came on and after being off all nite didn't want to start again. It is currently back at a Freightliner shop getting the rest of the injectors replaced. But first thing they said was wrong with it was the intake heater. I know that repairs are a way of live in this business but just don't seem to be confident with the repairs/service centers we have taken truck to. Do any of you have an opinion regarding the use of ether in this motor and if that could be the cause of our problems? All the work that has been done since San Antonio has been done at a Freightliner dealership. And the motor has 480,000 miles on it. Thanks for any input you might have to help us with our sitituation.
Granny Trucker
Granny Trucker
