Important Macro info
dadeo2my3
Carrier Management
LOADED MACRO:
Loaded Macro is now Macro 8…Macro 40 will no longer work.
MULTI LEG SHIPMENT (at same location / Same customer code):
If a shipment has more than one pick up or drop AT THE LOCATION (Same Customer Code Designation) then drivers only need to ARRIVE themselves (macro 2) on the first leg of that location. Example: stops 1, 2, 3, 4 are all here at Load One...once arrive on leg 1 the system will recognize that truck has arrived at leg 2, 3 and 4.
Once loaded (macro 8) system will allow driver to load on leg 1 and then scroll down and load at SAME LOCATION #2, SAME LOCATION #3 and SAME LOCATION #4. System gives drivers up to 9 additional legs location.
Same goes for the drop info. Example: If stops 5 and 6 are at the same location...driver would send arrival info (macro 2) for Leg 5. Once empty the driver can send EMPTY/POD info for Leg 5 but will be able to scroll to bottom and enter 2nd POD in SAME LOCATION #2 spot.
Please test them out both before you start blowing my phone up with questions. :rolleyes:
