Helpful Hints
geo
Subject: helpful hints & warnings
1) Flies or bees bothering you? Spray them with hairspray and they will take a quick dive.
2) Sealed envelope - Put in the freezer for a few hours, then slide a knife under the flap. The envelope can then be resealed. (hmmmmmm...)
3) Use Empty toilet paper roll to store appliance cords. It keeps them neat and you can write on the roll what appliance it belongs to.
4) For icy door steps in freezing temperatures: get warm water and put Dawn dishwashing liquid in it. Pour it all over the steps. They won't refreeze. (wish I had known this for the last 60 years!)
5) Crayon marks on walls? This worked wonderfully! A damp rag, dipped in baking soda. Comes of with little effort (elbow grease that is!).
6) Permanent marker on appliances/counter tops (like store receipt BLUE!) rubbing alcohol on paper towel.
7) Whenever I purchase a box of S.O.S Pads, I immediately take a pair of scissors and cut each pad into halves. After years of having to throw away rusted and unused and smelly pads, I finally decided that this would be much more economical. And now a box of S.O.S pads last me indefinitely! In
fact, I have noticed that the scissors get sharpened this way!
8) Opening brand new jars can be a feat in itself. Well, I have found a way to make it the easiest thing to do. Instead of banging a jar of jam, pickles,
etc., with a knife until it loosens up, I simply reach into the drawer and pull out the handy nutcracker. It adjusts to the size of the jar and I
simply give it a good twist and off pops the lid!
9) Blood stains on clothes? Not to worry! Just pour a little peroxide on a cloth and proceed to wipe off every drop of blood. Works every time!
10) Use vertical strokes when washing windows outside and horizontal for inside windows. This way you can tell which side has the streaks. Straight vinegar w ill get outside windows really clean. Don't wash windows on a sunny day. They will dry too quickly and will probably streak.
11) Spray a bit of perfume on the lightbulb in any room to create a lovely light scent in each room when the light is turned on. Place fabric softener sheets in dresser drawers and your clothes will smell freshly washed for weeks to come. You can also do this with towels and linen.
12) Candles will last a lot longer if placed in the freezer for at least
3 hours prior to burning.
13) To clean artificial flowers, pour some salt into a paper bag and add the flowers. Shake vigorously as the salt will absorb all the dust and dirt and leave your artificial flowers looking like new! Works like a charm!
14) To easily remove burnt on food from your skillet, simply add a drop or two of dish soap and enough water to cover bottom of pan, and bring to a boil on stovetop.
15) Spray your Tupperware with nonstick cooking spray before pouring in tomato based sauces and there won't be any stains.
16) When a cake recipe calls for flouring the baking pan, use a bit of the dry cake mix instead and there won't be any white mess on the outside of the cake.
17) Wrap celery in aluminum foil when putting in the refrigerator and it will keep for weeks.
18) When boiling corn on the cob, add a pinch of sugar to help bring out
the corn's natural sweetness.
19) Cure for headaches: Take a lime, cut it in half and rub it on your forehead. The throbbing will go away.
20) Don't throw out all that leftover wine: Freeze into ice cubes for future use in casseroles and sauces.
21). To get rid of itch from mosquito bites, try applying soap on the area and you will experience instant relief.
22) Ants, ants, ants everywhere ... Well, they are said to never cross a chalk line. So get your chalk out and draw a line on the floor or wherever ants tend to march. See for yourself.
23) Use air-freshener to clean mirrors. It does a good job and better still, leaves a lovely smell to the shine.
24) When you get a splinter, reach for the scotch tape before resorting to tweezers or a needle. Simply put the scotch tape over the splinter, then pull it off. Scotch tape removes most splinters painlessly and easily.
25) Now look what you can do with Alka Seltzer. * Clean a toilet. Drop in two Alka Seltzer tablets, wait twenty minutes, brush and flush. The citric acid and effervescent action clean vitreous China. * Clean a vase. To remove a stain from the bottom of a glass vase or cruet, fill with water and drop in two Alka Seltzer tablets. * Polish jewelry. Drop two Alka Seltzer tablets into a glass of water and immerse the jewelry for two minutes. * Clean a thermos bottle. Fill the bottle with water, drop in four Alka Seltzer tablets, and let soak for an hour (or longer, if necessary)
. * Unclog a drain. Clear the sink drain by dropping three Alka Seltzer tablets down the drain followed by a cup of Heinz White Vinegar. Wait a few minutes, then run the hot water.
Do your friends a favor. Pass this timely (and some not-so-timely) information on to a friend or two.
Subject: FYI
I was very glad to get this email from a friend, because I have been guilty of heating water in a microwave many times. You'll be glad you read it.
I also suggest passing it along to friends and family.
About five days ago, my 26-year-old son decided to have a cup of instant coffee. He took a cup of water and put it in the microwave to heat it up (something that he had done numerous times before). I am not sure how long he set the timer for but he told me he wanted to bring the water to a boil. When the timer shut the oven off, he removed the cup from the oven.
As he looked into the cup he noted that the water was not boiling. Then instantly, the water in the cup "blew up" into his face. The cup remained intact until he threw it out of his hand but all the water had flown out into his face due to the buildup of energy. His whole face is blistered and he has 1st and 2nd degree burns to his face, which may leave scarring.
He may also have lost partial sight in his left eye. While at the
hospital, the doctor who was attending to him stated that this is a
fairly common occurrence and water (alone) should never be heated in a microwave oven.
If water is heated in this manner, something such as a wooden stir stick or a tea bag should be placed in the cup to diffuse the energy. It is however, a much safer choice to boil the water in a teakettle.
Here is what our science teacher has to say on the matter:
"Thanks for the microwave warning. I have seen this happen before. It is caused by a phenomenon known as super heating. It can occur anytime water is heated and will particularly occur if the vessel that the water is heated in is new.
What happens is that the water heats faster than the vapor bubbles can form? If the cup is very new then it is unlikely to have small surface scratches inside it that provides a place for the bubbles to form. As the bubbles cannot form and release some of the heat that has built up, the liquid does not boil, and the liquid continues to heat up well past its boiling point.
What then usually happens is that the liquid is bumped or jarred, which is just enough of a shock to cause the bubbles to rapidly form and expel the hot liquid. The rapid formation of bubbles is also why a carbonated beverage spews when opened after having been shaken."
Please pass this on to everyone you know, it could save a lot of pain
Christyrose
Thanks for the hints and facts. This was interesting. What really surprised me was the Alka Seltzer and we drink that stuff!
Road Dog
The boiling water thing is typical of modern day "urban legend". That story is complete BS. I always get an extra laugh when whoever wrote the fiction includes testimony from an "expert". LOL! Good one Geo!
:p
