piattteam
Anybody know where the flashers are located in an International 7500?
The turn signals/flashers work fine, until the truck has been running for 5-7 minutes. Then the right side, front and mid-box lights won't flash.
The rear signal goes through the brake switch and works fine. (Is setup that flasher stops when you activate the brake.)
Wondering if it could be the flasher? Can't find the flasher though!!
Thanks.
Thanks.
