sweetbillebob
We are in our third Freightliner. All three truck's speedometers have not been accurate. In this truck we are going 62 when the speedometer says we are going 65. I have also run two checks on the odometer in this truck, I need to run one more just to be sure. The odometer says we have traveled 1025 miles when we have only traveled 1000. The point is, that when/if we limit, we will be limited at less than 65 if an adjustment in the "tire rev's per mile" is not also changed. I have run a 20, and 50 mile check, comparing mile markers with odometer and GPS. I plan to run a 100 mile check so I know how much to change "tire rev's per mile" before getting the limiter set. Changing the "tire rev's per mile" can be done at the same time the limiter is set, probably for no extra charge since most charge for 1 hour min.
