OWN 2 OF THESE, PLEASED WITH THEM BOTH. JUST MAKE SURE YOU ORDER ONE WITH ARM RESTS.GO TO DEALER AND SET IN ONE FOR ABOUT AN HOUR,SEATS TEND TO WEAR ON DRIVER.POWER IS EXCELLENT,TRANS WORKS WELL. HAD A FRONT WHEEL BEARING GO BAD.HEATER NEEDS A WATER INJECTOR TO PUT MOISTURE IN AIR HEAT IS SO DRY.CONSIDER RIDE TO BEST ON MARKET. HANDLE WELL WITH 3800 LBS IN BACK IF LOADED CENTER REAR AXLE.ALTOGETHER I GIVE THEM ABOUT A 9 OUTTA 10
