>Can someone explain the border crossing into Canada? What
>paperwork does the driver need, does the company who ownes
>the vehicle need to do anything special and does the shipper
>need to do anything? Also what paperwork is needed and what
>kind of premium should I charge to go into Canada.
This is a very interesting question:
I'm not sure,childsafe, whether you are inquiring as a "leased operator" or as a "for hire carrier".
If you are running as a Leased Operator you would run under the Leasing carrier's authority. You would be using their Carrier Code for example.
If however, you are planning to be the "Carrier" there are things you will need. You must apply to the Canada Border Services Agency for a Carrier Code. This identifies you to the CSBA and allows them to trace your shipments for any carrier infringements so they can assess penalties if necessary.
You must get PARS stickers, from an approved printer in the approved format so the CBSA readers can "read" them.
If you are a "leased Operator" or a driver for a "Leased Operator" driving for a company you must have these to attach to the invoices.Get them from the Carrier.
Driver's Paperwork: You must carry papers that show who you are and that you are authorized to drive the vehicle. You will be subjected to a criminal search, those with a criminal record can be denied entry into Canada as you are entering for business purposes.
Shipper:
The shipper must provide you with a true and accurate count of all goods loaded on your commercial vehicle. If you arrive to haul, as an example, 200 boxes on 5 skids, there must be 200 boxes. NOT 202 or 197.
If the Shipper loads and seals your vehicle without allowing you to observe this, mark the bill of lading:
SHIPPERS LOAD COUNT AND SEAL and have the shipper sign this.
Make them take the responsibility and make them pay any AMPS penalties.
The shipper will provide you with an invoice describing the goods:
Quantity, description, value, Country of Origin.
You attach your PARS stickers and fax this invoice to the Canadian Customs Broker. You must be told which Broker the shipper or the receiver uses. You must send this a minimum of 2 1/2 hours before you cross.
Go to the correct border crossing: if you are told to cross at Port Huron - Sarnia go there, not Detroit - Windsor.
Premium?
If you are a driver or Leased Operator how can you charge the Carrier a premium?
If you are a Carrier, will the shipper pay a premium?
That's up to you.
I hope this answers some of your questions.
I did not cover BOnded Operations in this message. That is a separate topic.
I'll look back here over the next few days to see if you have others.
Drive Safe(ly)
