2017 Hino 268 starting issue
HinoRich
Hi, I've been having a starting issue with my Hino.
For the past 2 weeks my truck will not start when I try to turn the key. It's intermittent but sometimes it won't start at all.There are no dash lights or anything but there is power, the radio and blower fan, headlights, etc do work, but the truck will not start or even attempt to, I did turn the key on and off about 10-15 times today and the dash finally did light up and I was able to start the truck. I have had connections cleaned and all the major wiring to the starter cleaned. Fuses checked. I have replaced the batteries, ignition. Is there a relay or solenoid that could be bad?
LostDeere59
I would read the Hino sub-forum in the Truck Talk section - there is a TON of good information there, and since you didn't give model/year for your truck you can sort through it based on what you have.
Gregg
HinoRich
Thanks Gregg for the reply. I was thinking I did have that info in there. It is a 2017 268.
