Rick Welcome!!! DMX is a very good small courier company to work for. You just happen to be in the wrong part of Mi. Most courier work is on the other side of Mi and into and out of Canada. Most of the deliveries couriers do are mostly from their home 20 to BFE, and nothing to bring you back home, unless you are running local. If you want courier work and do 2 to 10 trips a day you should switch to a bigger better known company.
If you get your authority and your own work, you will be doing the same thing. Deadheading home or to the next pick up and that is where???? 100 miles away from your last drop, and how long do you have to wait, or how many trips will you miss because you are to far away????
Finding expedite loads on a board is also a joke!!!!!!!!! WHY??? Because people don’t put hot loads on a board. An expedite load has to go now, not in a day or two. So most people that need an expedite delivery only call the people they already know. Most people working in an office for a corp. want things to run smooth. They hate to have to change because that means they have to do a little work or may have to think a little more.
You can join the boards at $35 a month and find a load a week as you say you want to do or you may not. BUT!!! You may also be adding another bill for your wife to pay. Can you afford that gamble???
If you want to do this thing on your own, I hope you know you must put in a lot more hours than doing 1 load a week. Your insurance is way more than what 1 load will pay. Being on your own isn’t all that easy, trust me. Most guys think it is the cats XXX!!!!! But let me tell you it’s not. You must learn to wear 3 or 4 hats!!! Most companies using expediters don’t like to use a one horse team. They feel that you can’t supply their demand. Now can you afford to hire or have the work to run 2, 3, or 4 other drivers? It is real hard to sell yourself to a company. When I started doing this thing on my own I had to start out as a back up to others and would only get 1 or 2 trips a month from a company. I found 10 companies and did it that way for a good long time. It only took 3 years till I found the key on how to service these companies before I started doing well enough on my own.
Some things you should be aware of, being on your own are: a company using you to do a trip, then not pay you!!! If you ask for the money up front, you more than likely won’t get the job. You have to know who is good and who isn’t. Another thing you may want to look out for is the other 1 horse team under bidding you. Remember if a company is calling you for a price on a trip he is also calling 2, 3, or 4 others looking to get the best rate. This is a cut throat business, but then you should already know that.
I would have to tell you to trip lease 1 trip or 2 a week with other already established companies!!! OR maybe find a local courier company that will give you more trips a day or week. GOOD LUCK!!!
