raceman
As I told you in an earlier message, I had a real bad experience out in Indiana with a garage. I am still fighting this with the BBB and Att. General office and a Lawyer. The problem is bad enough that I want to be sure you are warned. I69 Truck and Trailer outside Muncie, it is actually Daleville, Indiana. If you have problems out there I highly recommend you stick to the Freightliner shops or other garages in that area. I69 T&T overcharges and it turns out they are using junk yard parts. If you are lucky enough to get out of there garage and breakdown following the repair, no need to call them. They do not stand behind anything they do and for good reason. This place is ripping off drivers in need and they hope they get far enough away before all hell breaks loose that they call someone else to fix what they overcharged for and screwed up. If you want more detail just ask and I will fill you in. Stay clear of that place or you will be sorry.
raceman:-(
raceman:-(
