theoldprof
This is not truck related, but I hope somebody has the info I need. Recently bought wifey a tall clock. It has a battery movement. It also chimes. I can turn off the chimes, but they are off all the time. The "chimes" are a small speaker about 2 inch diameter with a double wire running from the speaker to the mechanism. I would like to lower the volume of the chiming all the time. Can a volume control switch (a rheostat?) be installed in the wire going to the speaker to lower the speaker volume? If so, is there a + and a - speaker wire? Can the control switch be wired into either wire? If such an animial is available, where can I get it. Thanks.
