rollnthunder
Ok here it goes i have a 2000 Fl-106 with a detroit engine.I have the block heater plugged in and it seems to be working the side of the motor is luke warm.I go to start it and it cranks really slow.I have had the batteries tested at 2 different places and they are about a year old.( 3 batteries)I have also pulled all the battery cables loose and cleaned them and reassembled and used protectant spray.When i got to start it the volt gauge will be up around 12 to 13 volts but when i crank it they will drop to 11 or so.And it cranks really slow.Now if i go and fire up the generator and let it run for a 1hr or so it will start.I checked the batteries volts and they where at 12.5 before starting the generator so i dont think its a Electrical Draw.Everything is off.Could it be the starter is dragging and drawing to much current.Also even when its warmed up i dont think it cranks all that fast.
